taeseoplim
#1 Posted : Saturday, July 15, 2017 1:12:14 PM(UTC)
taeseoplim
My down-draft Jenn-Air (JES9900BAS) range/oven's LED lights up and works.
But, the oven does not heat up at all, and the burners do not heat up or light up the red heat-on button.
What might be the problem here.
Taeseoplim.
taeseoplim
#2 Posted : Tuesday, July 25, 2017 12:14:56 PM(UTC)
taeseoplim
The problem is the burnt power inlet.
At the lower left side of the back of the unit, there is power in-let. 220 Volt electric chord is divided into three lines: white, black, and green.
The green line was burnt and disconnected.
So, I need a new power chord. Could you tell me the part number?
taeseoplim attached the following image(s):
taeseoplim
#3 Posted : Wednesday, August 9, 2017 10:43:22 AM(UTC)
taeseoplim
I bought Whirlpool power cord that was exactly the same as the one on my Jenn-air, and installed it. Not it works fine.
taeseoplim
#4 Posted : Wednesday, August 9, 2017 10:46:21 AM(UTC)
taeseoplim
Whirlpool Range/Stove/Oven Power Cord PT500
taeseoplim
#5 Posted : Wednesday, August 9, 2017 10:50:25 AM(UTC)
taeseoplim
Now, the unit works fine other than one problem.
The downdraft vent speed does not change.
My unit has "low - high" 2-speeds. The speed on the LCD panel changes, but the actual fan speed remains low.
I assume there is a part controlling the speed of the motor. Where is it and what's the part number?
I hope this time I get some help.
taeseoplim
#6 Posted : Wednesday, August 9, 2017 11:09:02 AM(UTC)
taeseoplim
Another issue is that the neighboring area of a burner is also getting warm. Usually, the round area of a burn is hot but the vicinity is cool. Isn't it?
