LoneStarAppliance
#1 Posted : Thursday, September 22, 2016 3:55:36 AM(UTC)
LoneStarAppliance
I have a Frigidaire Affinity AGQ7000ES1.
The dryer has stopped spining after a minute or so and saying 'pau.'
When I try to restart it it says 'dr.'
When I press start again it will run for a few seconds and repeat.
I replaced the door switch and lamp. Light comes on when door opens and the door latches securely.
I rain field test mode and got the following codes (corresponding to the light stack:
r06
E04
E4A 026
C01 00 925
186 791
086
Can someone explain these codes to me, I tried the Tech Data Sheet, but E04 and E4A don't seem to be listed in there.
Thanks,
LoneStar:confused:
LoneStarAppliance
#2 Posted : Monday, September 26, 2016 8:35:35 AM(UTC)
LoneStarAppliance
Anybody have an idea? I don't want to buy a new control board unless I really need one, but since I have a new door switch (tested, confirmed working) I'm thinking it might be something board related.
LoneStarAppliance
#3 Posted : Saturday, October 1, 2016 4:34:36 AM(UTC)
LoneStarAppliance
after running field test mode again and confirming that the moisture sensor was working and the thermostat seemed functional I went ahead and replaced the control board. $150 and I have a known-good dryer again.
I know nobody is reading this post, but now if someone ever has a similar problem in the future they won't be left high and dry like this.
