Hello all! I have been working on both my washer and dryer for quite sometime now. I can't even begin to tell you everything that has happened but needless to say, I currently have 2 washers and 2 dryers. Each one has something wrong but why wouldn't they! :) For now I will focus on my dryer. I have a Kenmore 110.66722694 that has had multiple issues. First, it had no heat, then electrical issues, then the timer wouldn't stop on timed dry, and now its too hot. What I have done so far: Replaced the heating element and thermal fuse, cleaned the entire unit, repaired my timer, and "reset" the "non" resettable thermostat. I have checked continuity for all thermostats and fuses. Everything was good so I reassembled the dryer and used it. Noticed the top was getting really hot and the clothes themselves. My thinking is this: (once I receive answers on here and when I can pull the dryer out again though to test everything again) Could I use the thermostats from a different dryer model # 110.86071110 to put in my current dryer if they also test good? Both are Kenmore dryers and I know they are different part #'s but if the tempatures and everything else match, I don't see why I couldn't? I don't have the money to keep replacing things or the money for a new set. I am just trying to do the best I can with what I got. Lol Mother of 3 boys and no laundry is not ideal. Thank you all so much! Any and all advice welcomed!!!
