Hi folks,
I picked up a used Kitchenaide Superba model number kuds01djss1 at the Habitat Re-store a few weeks ago. It's been working splendidly, right up until last night when the control panel froze.
There is power to the control panel. When I tried to start it, the "add dish" led was on. When I open the dishwasher and close it, the "baked on cookware" and "sani-rinse" leds turn on for a few seconds and then turn back off. It does not respond to any of the buttons though. Leds do not turn on when I hit a button.
I tried the reset sequence that I found on another forum with no results. (The reset sequence used was reported to be the following: 1) Crack the door open. 2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry 3) Close and latch the door 4) Press the cancel button (the circle with the triangle in it))
Any guesses to what is going on or what to try next? Thanks!
