olgra
#1 Posted : Tuesday, October 6, 2015 11:20:52 AM(UTC)
olgra
idler pulley froze,stoped dryer...repaired pulley...dryer won't start,...timer was an issue-not accurate ,replaced....replaced control board (guess),available rebuilt...power up ..start button works,timer will run for 5-10 sec. then stop...tested drum motor,door switch,thermal fuse,all good,...am I missing anything ?many thanks for any help-idea.....Patrick...e-mail ...mk2jag@att.net
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Kenmore gas dryer model 110.96742701 (Dryer Repair)
by Guest 2/8/2024 9:07:42 AM(UTC)
Kenmore gas dryer overheating and shutting down in permanent press setting (Dryer Repair)
by Actonite 8/14/2022 4:57:32 PM(UTC)
Kenmore Gas Dryer wont stay hot (Dryer Repair)
by johnmeyers 2/12/2021 2:05:37 PM(UTC)
Kenmore Gas Dryer - No Heat (Dryer Repair)
by smackover 10/6/2018 5:55:17 PM(UTC)
Kenmore Gas Dryer Timer (Dryer Repair)
by keepitfromthedump 5/24/2017 2:18:27 PM(UTC)
Kenmore gas dryer won' dry clothes all the way (Dryer Repair)
by ggarnett 1/2/2017 7:51:16 AM(UTC)
Kenmore Gas dryer wnot heat (Dryer Repair)
by wardm6 7/9/2016 11:30:51 AM(UTC)
kenmore gas dryer runs only when push to start is pressed in (Dryer Repair)
by carlosjbb 12/12/2015 11:34:10 PM(UTC)
Kenmore gas dryer heats intermittently (Dryer Repair)
by Nordillaca 12/12/2015 7:33:46 AM(UTC)
Kenmore Gas Dryer intermittent (Dryer Repair)
by diyeng 2/24/2014 10:01:39 AM(UTC)
Kenmore Gas Dryer won't Heat (Dryer Repair)
by rboysen 2/5/2014 5:57:38 AM(UTC)
electrolux/kenmore gas dryer fault (Dryer Repair)
by iclad 1/28/2014 12:53:59 PM(UTC)
No heat - Kenmore gas dryer (Dryer Repair)
by Brian Effinger 11/7/2013 1:11:12 PM(UTC)
Kenmore Gas dryer, no heat control (Dryer Repair)
by iowacows 8/13/2013 4:18:50 PM(UTC)
