Groups ready for retrieval: Registered
I have a Whirlpool Double Oven Model RBD306PDB12 that is approximately 12 years old. The display has stopped working. All the buttons still beep when pushed. If I turn the power off and back on the oven will try to work. It will start to warm up but after about 30 seconds it turns off and beeps. The display never works during all of this.
My question is do you think it is the control board which is NLA or could it be the control panel which is still available? Also is there a way I can test either to see what the problem may be?
Thanks very much.
RDLearned
Here are your parts Parts for Whirlpool RBD306PDB12 Oven - AppliancePartsPros.comSounds like a control board problem. All the control panel does is input switch closures to the control board and since you are getting beeps I would say it is OK. There are companies out there that will repair obsolete control boards/timers. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman Here are your parts Parts for Whirlpool RBD306PDB12 Oven - AppliancePartsPros.comSounds like a control board problem. All the control panel does is input switch closures to the control board and since you are getting beeps I would say it is OK. There are companies out there that will repair obsolete control boards/timers. Thanks. I had seen that parts list. My board is NLA. I sent it off to be rebuilt yesterday. Will update with results when I get it back.
Originally Posted by: RDLearned Thanks. I had seen that parts list. My board is NLA. I sent it off to be rebuilt yesterday. Will update with results when I get it back. Received rebuilt board Friday afternoon. Sent it to fixyourboarddotcom. All is fine now. Thanks for the help.
