William8294
#1 Posted : Tuesday, October 28, 2014 8:02:53 PM(UTC)
William8294
To whom it concerns,
The washing machine just started acting up tonight. So here goes, The washing machine will not fill up with water, and it seems it will not cycle through the full/entire cycle from start to finish. Curious to what could the problem be?
Thank you,
Bill
fairbank56
#2 Posted : Wednesday, October 29, 2014 4:43:07 AM(UTC)
fairbank56
Groups: Expert
We need the model number of the washer. It's not going to advance through the cycle if it can't fill up with water.
Eric
William8294
#3 Posted : Wednesday, October 29, 2014 6:05:47 PM(UTC)
William8294
Here's the model #... 29822800
fairbank56
#4 Posted : Wednesday, October 29, 2014 6:17:04 PM(UTC)
fairbank56
Groups: Expert
This is a load sensing model. May be a faulty load sense switch. Will the washer spin if timer is manually placed into spin function?
Eric
William8294
#5 Posted : Wednesday, October 29, 2014 7:50:53 PM(UTC)
William8294
Yes, if we manually turn the switch it will start to spin.
fairbank56
#6 Posted : Thursday, October 30, 2014 4:58:52 AM(UTC)
fairbank56
Groups: Expert
Ok, so that means the lid switch is good. The problem is most likely the load sense switch. Place timer into the rinse fill portion of the cycle. Rinse fill bypasses the temperature switch. If it still won't fill there, then I would replace the load sense switch. This is your front panel fabric softener switch. Any part ordered from APP can be returned if it doesn't fix the problem.
Whirlpool W10292584 Switch-Sen - AppliancePartsPros.com
Eric
GE washing machine...clothes stuck! (Washer Repair)
by kaslonancy 2/21/2008 2:39:00 PM(UTC)
