Just replaced the 9759243 thermostat that blows every time you self clean these models. Now when I turn on the oven, the large front burner ignitor sparks on the stove but neither the bake or broil ignitor glow. Could it be a simple as the replacement thermostat is bad or did the self clean situation cause another part to fail? Stove works fine, front panel, timer and controls seem fine.
