Our microwave has no power - no lights, buttons or anything. It was run on high by accident for approximately 20 minutes before death. So far, I have replaced the 20a ceramic fuse and the magnetron thermal fuse. The door switch seems OK, It at least "Sounds" like it is going on and off. Are there any other fuses that can cause total power failure? Thanks, David
