Thejodoins
#1 Posted : Sunday, July 21, 2013 5:40:54 AM(UTC)
Thejodoins
Out of the blue, the washer does not kick in after fill
I've checked fundamentals so looking at ideas to fix. Please!
fairbank56
#2 Posted : Sunday, July 21, 2013 6:28:00 AM(UTC)
fairbank56
Groups: Expert
Could be lid switch, timer, pressure switch, level selector or motor. Does it drain/spin? If so, lid switch and motor are ok. Have you tried all three water level selections?
Eric
Thejodoins
#3 Posted : Sunday, July 21, 2013 6:35:28 AM(UTC)
Thejodoins
Thanks Eric
It does not spin or drain or agitate
Different water levels appear to work as when I switched to higher, water would continue filling and then stop
I am thinking I should look at the lid switch assembly but how the hell do you get access to it?
John
fairbank56
#4 Posted : Sunday, July 21, 2013 6:58:16 AM(UTC)
fairbank56
Groups: Expert
I'm not that familiar with this model. Looks like you need to remove the front panel (2 screws near bottom) to gain access to screws that hold top panel on. What is the serial number of your washer? There are different lid switch assembly part numbers based on the series of your washer.
Eric
Thejodoins
#5 Posted : Sunday, July 21, 2013 10:07:30 AM(UTC)
Thejodoins
Thanks Eric
I found the two bolts and the top slid off
I then removed the lid switch assembly and found two switches
A black pressure switch which I tested to work fine , simple single pole
There was a smaller white pressure switch which had a lot of corrosion on one of the electrodes. I cleaned it up and tested the switch. One of the connectors has no continuity to either of the other two connectors with pressure switch activated or not, which tells me it may be defective
I suppose if my assessment is correct I need to order a complete lid switch assembly
That make sense to you?
John
fairbank56
#6 Posted : Sunday, July 21, 2013 12:10:26 PM(UTC)
fairbank56
Groups: Expert
You can just replace the white switch (check switch).
Whirlpool 207166 Lid Check Switch - AppliancePartsPros.com
These lid switch assemblies are overkill in my opinion. The black switch is the lid switch, the white one is the check switch. They are in series and both must close for the motor to operate. The other terminal on the check switch is to blow the fuse in the water fill valve circuit in the event that the lid switch fails in the closed position (welds shut). Blowing the fuse prevents you from filling the washer so it's basically useless until you replace the lid switch.
Eric
Thejodoins
#7 Posted : Sunday, July 21, 2013 6:39:43 PM(UTC)
Thejodoins
Thanks. I now have the check switch on order. I will let you know how it goes
John
Thejodoins
#8 Posted : Sunday, August 25, 2013 4:16:59 AM(UTC)
Thejodoins
Yeh. I changed that little pesky switch, that I know I pad too much for, but what the heck! It works like a charm
Thanks for your help
