AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Washer won't do spin cycle under DELICATE setting..
Our washer won't do the spin dry after rinse, but ONLY when we are using the Delicate setting. I does so under Colors and Whites.
Any thoughts???
Thanks...
Groups: Expert
Assume you mean MAV7000? Sounds like a faulty timer. Eric
Yes, sorry, fat fingers. MAV7000.
Is is possible to get a timer? Also, I'm assuming it is fairly easy to replace?
Depending on the cost, I might not fix it as the other spin cycles work so we just have to turn it to one of the others ones after it rinses.
Groups: Expert
Washer Repair
