Welcome Guest! To enable all features please Login or Registers.
allen9258
#1 Posted : Thursday, March 7, 2013 5:01:31 PM(UTC)
allen9258
This washer will fill agigate and rinse fill but will not spin it pumps the water out and if i push down the lid switch and turn the drum counter clock wise it tries to spin this way as if the clutch is bad or there maybe a transmission problem i am unable to tell between the two exactly which one is the cause
fairbank56
#2 Posted : Friday, March 8, 2013 5:53:47 AM(UTC)
fairbank56
Groups: Expert
Remove the front panel and rotate the motor pulley by hand clockwise (viewed from below). Use two hands as you must keep the pulley going in order for the brake on the transmission to stay released. The motor pulley, belt, main drive pulley, transmission and basket should all rotate fairly easily. If it's difficult, there may be clothing stuck between the tubs or a problem with the brake release on the bottom of the transmission. If it does rotate fairly easily, run it in spin mode while observing the motor pulley and the clip on the bottom of the motor shaft. If the clip is spinning but the pulley is not, then the clutch is slipping.
Eric
** LG Washer wont spin - LE Error ** WM4070HVA (Washer Repair)
by jborka 3/14/2024 6:15:24 PM(UTC)
GE Washer wont spin at the high speed GHWN4250D0WW (Washer Repair)
by ssauer40 1/10/2022 4:19:44 AM(UTC)
washer wont spin (Washer Repair)
by allen9258 4/8/2018 11:08:33 PM(UTC)
Maytag Bravos Washer wont spin (Washer Repair)
by utzzy27 10/2/2016 1:15:15 PM(UTC)
washer wont spin out (Washer Repair)
by dokratt 4/16/2016 2:50:25 PM(UTC)
Maytag Neptune washer wont spin or cycle (Washer Repair)
by Tonya 44 11/17/2015 12:56:58 PM(UTC)
ge washer wont spin or agitate (Washer Repair)
by outback32 9/29/2015 9:46:08 AM(UTC)
by Denarae 8/4/2015 7:21:30 AM(UTC)
Frigidaire Washer Wont spin high speed (Washer Repair)
by jchi2210 12/17/2014 12:01:09 PM(UTC)
washer wont spin& drain (Washer Repair)
by aristeoherrera@gmail.com 12/10/2014 3:19:57 PM(UTC)
by lvest 7/26/2014 11:09:50 AM(UTC)
by Mattbri 5/30/2014 11:16:21 AM(UTC)
ge profile washer wont spin (Washer Repair)
by ron1821 3/24/2014 4:57:26 PM(UTC)
GE profile washer wont spin (Washer Repair)
by ron1821 3/19/2014 11:31:36 AM(UTC)
Maytag washer wont spin, smoking from under and smells like burnt rubber (Washer Repair)
by trytodiy 3/13/2014 6:20:43 PM(UTC)
