evckam
#1 Posted : Friday, April 17, 2009 12:20:41 PM(UTC)
evckam
My dryer stopped heating but still powers, here is the what I have checked so far and I am looking for the next possible cause for the issue;
1. I made sure the circuit breaker is not tripped
2. I made sure dryer gets 220 volts at the wall socket
3. Unplugged the dryer and checked the main terminal block for damage
4. I checked the thermal fuse for continuity with an ohmmeter
5. I checked the heating element for continuity
6. I checked thermal cut-off for continuity
So far everything checks out and I am not sure what to do next. Any help or input would be greatly appreciated. TY
Drags1998
#2 Posted : Friday, April 17, 2009 2:13:35 PM(UTC)
Drags1998
Check the other 2 Thermostats You should be able to read continuty Thru ALL thermostats.
evckam
#3 Posted : Friday, April 17, 2009 2:34:58 PM(UTC)
evckam
I went back and found the one I missed, I don't have continuity
on the Thermal cut-off Thermal cut-off for dryer heating element 309 degrees (includes high-limit thermostat), I will run to the local appliance repair store in the morning for a replacement.
Thanks for the help!
Drying not heating (Dryer Repair)
by dalekmaidens 12/21/2011 7:10:59 PM(UTC)
