Ekauserud
#1 Posted : Tuesday, January 29, 2013 7:09:30 PM(UTC)
Ekauserud
Hi all, and thanks again!
I just replaced the ENTIRE guts of my washing machine. It ran perfect until now. There is a leak on the floor on the right side(half) of the machine soaking the floor. This is the problem that started last time and forced me to fix the whole assembly. Are there any clues here, right side leak coming out the front. Just curious before I start tearing it apart. Thanks!
#2 Posted : Wednesday, January 30, 2013 2:06:20 PM(UTC)
Hello,
Remove the washer cabinet and bypass the lid switch. Run a load and watch for a leak. Post the results.
Here are the breakdown diagrams and Parts for Whirlpool LTE6234AW3 Washer Dryer Combo - AppliancePartsPros.com
Ekauserud
#3 Posted : Tuesday, February 19, 2013 4:43:16 PM(UTC)
Ekauserud
It looks as though the leak is coming from the transmission case. When small loads are done it doesn't leak or not nearly as much. I am angry because I JUST replaced all the seals.
Ekauserud attached the following image(s):
#4 Posted : Wednesday, February 20, 2013 3:11:13 PM(UTC)
Did you replace the transmission shaft seal and the shaft seal (#3 & #4 at the diagram)?
Leaky washer.....already replaced tub seal (Washer Repair)
by Sherm1082 2/23/2014 4:32:49 PM(UTC)
Please Help, Leaky Washer. (Washer Repair)
by anj277 5/14/2013 7:47:53 AM(UTC)
leaky washer (Washer Repair)
by ozzy29 8/11/2012 12:19:15 PM(UTC)
Leaky washer (Washer Repair)
by kcfinest62 12/29/2010 12:56:50 PM(UTC)
by Jeanne Cartwright 3/20/2008 10:15:17 AM(UTC)
