drpetey1
#1 Posted : Tuesday, January 8, 2013 3:22:09 AM(UTC)
drpetey1
Hello everyone,
I was wondering if someone could help me out. I have a maytag centennial. mod.num. MVWC6ESWW1. I have a puddle of water on the floor. It begins to agitate while its filling and after the spin cycle it shoots water in soaking the clothes. Any input would be appreciated. thanks
fairbank56
#2 Posted : Tuesday, January 8, 2013 5:19:52 AM(UTC)
fairbank56
Groups: Expert
The symptoms of agitating while filling and the extra water at end of spin point to a bad auto load sensing switch. This is a high failure item on this washer. I would first check the hose that runs from this switch to the air dome on the lower right rear quadrant of the outer tub. If the hose is loose/split/cracked, it can leak water and cause the switch to not operate properly. Normally, the air dome and hose present an airtight seal. As the water level in the tub increases it compresses the air in the dome and hose and the switch monitors this pressure to determine water level. Also, make sure there is no gunk buildup in the air dome and hose. If it checks out ok, I would replace the switch and look for the leak elsewhere.
Eric
