Rank:: Member
Groups ready for retrieval: Registered
Child Safe mode will not release. Replace control panel? Or is there somthing I am over looking?
Have you tried unplugging/remove power from the unit for a couple minutes to see if it will reset? |
THIS FORUM IS DEAD!!!!!!! |
Rank:: Member
Originally Posted by: denman Have you tried unplugging/remove power from the unit for a couple minutes to see if it will reset? Yes, no change
Here are your parts Parts for Whirlpool KUDS25SHWH1 Dishwasher - AppliancePartsPros.comSee the attachment for the tech sheet. Unforetunately it does not give a pin-out for the keypad. The problem will be either with the keypad or the control board. If the lock light is flashing I would try the keypad first as this could be a stuck key problem. If it is on solid I would replace the control board. Either one is a bit of a gamble. |
Rank:: Member
Light does flash, but i don't see a separate part for the pad only control assy. My unit is white and the only one I see available is black! If it is a stuck key and can be freed.That would be nice. Thanks denman
Give the parts people a call they have more info than I do. There are a number of versions of the control panel listed but they are all just black. They should be for the different colors so it may just be a problem with this data set.. Always a possibility that the other colors are no longer available, only the parts specialists will know.
Unsticking a key is very iffy. Thy are usually bubble type keys. There is a possibility that if you remove the panel and put it in a freezer overnight that the thermal contraction caused by freezing it will pop it back up.
I used to use a product called FreezeIt re: a freezing spray, to just freeze the one key area. This may mess up the plastic protective cover. Works maybe 1 in 10 times. |
