ontariocanada51
#1 Posted : Sunday, April 12, 2009 9:39:03 AM(UTC)
ontariocanada51
everything works but the oven 6 months old glass top the model numbers i have just dont click i just need to know is there a fuse block in this stove?
#2 Posted : Sunday, April 12, 2009 11:37:35 AM(UTC)
It will be a Canadian model so finding info is a pain.
There is not a fuse box in modern units.
If stove went out after a self clean, it is often a thermal cutout/fuse attached to the back or sometimes the top of the oven case on the outside.
I assume the stove top works correctly and is electric.
If it is a dual fuel could be you do not have 240 volts, sometimes you can loose half the line without actually tripping the breaker. Turn breaker off/on slowly a couple times.
Put in a service call and get it repaired under warranty.
If you open it up you could void your warranty also it could be something more expensive to repair like the electronic control board.
another canuck
Viking gas broiler and oven not working (Oven Repair (including Ranges and Cooktops))
by Guest 12/4/2023 2:39:31 PM(UTC)
Dacor oven, upper oven not working (Oven Repair (including Ranges and Cooktops))
by notyepcars 11/26/2022 8:40:21 AM(UTC)
oven not working, gives me a code F3 (Oven Repair (including Ranges and Cooktops))
by cj9113 10/16/2021 7:56:35 AM(UTC)
GE PROFILE PGB995DET1WW Top oven not working (Oven Repair (including Ranges and Cooktops))
by Guest 9/6/2021 9:36:45 AM(UTC)
Whirlpool microwave/oven not working (Oven Repair (including Ranges and Cooktops))
by naik71 9/3/2020 5:51:16 PM(UTC)
Thermador oven not working DP366CS/03 (Oven Repair (including Ranges and Cooktops))
by Chanmomu 6/30/2020 5:07:14 AM(UTC)
whirlpool WOD93EC0AS double oven bottom oven not working (Oven Repair (including Ranges and Cooktops))
by Chemsal 3/18/2020 3:28:11 AM(UTC)
KDRP467KSS08 / KDRP467KSS0 KitchenAid oven not working (Oven Repair (including Ranges and Cooktops))
by larrywick 10/18/2019 2:28:40 PM(UTC)
Oven On light stays lit - Oven not working properly (Oven Repair (including Ranges and Cooktops))
by Lometir 3/20/2019 7:54:34 AM(UTC)
ge oven not working (Oven Repair (including Ranges and Cooktops))
by mcp1212 9/25/2018 1:00:51 PM(UTC)
maytag range oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by tpwd 3/27/2018 3:28:20 PM(UTC)
Whirlpool Accubake Oven Not Working (Oven Repair (including Ranges and Cooktops))
by buddha61 11/15/2017 5:18:32 PM(UTC)
Maytag oven not working (Oven Repair (including Ranges and Cooktops))
by dtmeyer 10/14/2017 12:48:25 PM(UTC)
Oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by Nalk 1/20/2017 7:05:57 PM(UTC)
stove oven not working but burnerws do (Oven Repair (including Ranges and Cooktops))
by jnevill1 1/1/2017 7:20:12 AM(UTC)
