Here are your parts, includes a wiring diagram.
Replacement parts for Crosley CDE6000W DRYER- ELE | AppliancePartsPros.comI am assuming the unit runs, just does not heat.
I would start by checking the power.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]
Be careful as 240 volts is lethal !!![/COLOR]
Next check the heating coil, should be around 12 ohms.
Then check the thermostat, then the safety thermostat, both should be 0 ohms.
If the safety thermostat is blown add this to your post as there are other things that should be checked before replacing it.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
