Johnwg
#1 Posted : Sunday, July 15, 2012 1:08:39 PM(UTC)
Johnwg
I replaced the lower heating element in my oven after some fireworks - the element popped in two, and burned a hole in the lower pan. After replacement, it's not heating. Could it be the oven control board or the temp sensor? There is no thermal fuse in this unit. Model #FEF366EMD. Any help is appreciated.
#2 Posted : Monday, July 16, 2012 1:59:27 AM(UTC)
Replacement parts for Frigidaire FEF366EMD Frigidaire/range | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/p...pringfield/316441437.pdf
Do the stove top elements work?
Does the broil (upper) oven element work?
Odds are that the control board is toast.
I would remove the rear cover and check that the wiring to the elements is OK.
Johnwg
#3 Posted : Tuesday, July 17, 2012 4:46:29 PM(UTC)
Johnwg
Originally Posted by: denman Go to Quoted Post
The upper heating element does not work, but the stove top works fine.
#4 Posted : Wednesday, July 18, 2012 3:00:20 AM(UTC)
OK, so the unit is getting 240 volts therefore it is either a wiring problem or more likely the control board is shot.
Johnwg
#5 Posted : Thursday, July 19, 2012 5:17:23 PM(UTC)
Johnwg
Thanks Denman, is it an easy swap to change the control board?
#6 Posted : Friday, July 20, 2012 2:05:01 AM(UTC)
Depends on your definition of easy.
If you click on a part's picture a new page will open often with more views and a Q&A section. This often has install info.
Looks like you remove the rear cover to get at it,
Then it is either held in by a few screws or by clips.
If clips be careful that you do not break them.
You may also need a new overlay (Item20A in Section 1)
Looks like it is a peel and stick.
Just be sure to unplug or flip the breaker when working on it.
If wires can go a couple different places be sure to swap one at a time or make a list/diagram where they go.
