jbarbero
#1 Posted : Wednesday, June 27, 2012 4:39:06 PM(UTC)
jbarbero
Frigidaire side by side fridge is freezing.
Model number: Frs23bh6cs0
Freezer seems to be working fine
I did turn the fridge side off until I heard the damper door close, then turned it on to setting 2 well below factory setting. Still freezes everything. Please help
Thanks James
Simon / APP Team
#2 Posted : Wednesday, June 27, 2012 5:11:39 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi, James.
First adjust the freezer temp to warmer setting. Give it 12hrs and check freezer temperature. See if that make a difference in the refrigerator side.
If at let say 0*F in the freezer it still be freezing produce in the fresh food then replace the damper thermostat #21
Part number: 240383703
Use the old insulation tube.
Here are the breakdown diagram and Controls replacement parts for Frigidaire FRS23BH6CS0 Frigidaire/refrigerator | AppliancePartsPros.com
Thank you. Post the results.
Simon.
jbarbero
#3 Posted : Wednesday, June 27, 2012 5:27:52 PM(UTC)
jbarbero
Awesome! Will try tonight. I'll post the results tomorrow.
James
jbarbero
#4 Posted : Thursday, June 28, 2012 4:48:29 PM(UTC)
jbarbero
Adjusted the freezer control to warmer temp. No change in fridge. Everything is still frozen.
Simon / APP Team
#5 Posted : Thursday, June 28, 2012 5:08:56 PM(UTC)
Simon / APP Team
Groups: APP Team
What is the freezer temp.? If it around 0 F - replace the control I mention earlier.
Thank you.
Simon.
jbarbero
#6 Posted: : Thursday, June 28, 2012 5:43:05 PM(UTC)
jbarbero
I'm embraced to say it but I can't find my thermometer. I'm going to go get another tonight and re run the test. I'll post an update
James
jbarbero
#7 Posted : Friday, June 29, 2012 7:52:47 PM(UTC)
jbarbero
Simon,
Confirmed temp in freezer is just above zero.
James
Simon / APP Team
#8 Posted : Monday, July 2, 2012 9:49:18 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Replace the cold control. You have the info.
Simon.
jbarbero
#9 Posted : Tuesday, July 3, 2012 7:06:56 AM(UTC)
jbarbero
Thank you so much! I can't tell you how much I appreciate your help.
James Barbero
Simon / APP Team
#10 Posted : Tuesday, July 3, 2012 10:19:10 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
