hogo
#1 Posted : Tuesday, June 5, 2012 10:46:38 AM(UTC)
hogo
My whirlpool refigerator stopped cooling completely after I turned the temperature control down a little. The fan continues to run and the compressor has a low hum to it but never seems to get going. I tested the starter relay and its working so what should I try now? Got compressor running but still not cooling. Any ideas?
Simon / APP Team
#2 Posted: : Tuesday, June 5, 2012 4:49:47 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Remove the rear cover and check how the evaporator coils are covered with frost if covered at all.
Please, post the results.
Simon.
hogo
#3 Posted : Wednesday, June 6, 2012 2:01:50 PM(UTC)
hogo
There's nothing on the coils and never was when it stopped cooling. The compressor stays on as does the fan. What doesn't make sense is the problem started when the fridge temperature dial was adjusted.
hogo
#4 Posted : Wednesday, June 6, 2012 2:08:18 PM(UTC)
hogo
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
Thanks for your response, there's no ice, just a mystery. The temperature went from cold to not cooling at all when I turned the temperature dial/adjustment down a bit.
Simon / APP Team
#5 Posted : Wednesday, June 6, 2012 10:43:30 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
It is a mystery. Most likely it's a sealed system problem.
Before calling the pro check if compressor gets 120v.
Thank you.
Simon.
hogo
#6 Posted : Thursday, June 7, 2012 5:55:18 PM(UTC)
hogo
Hi.
Thank you.
Simon.
If the overload relay is faulty would the compressor run but not cool?
Simon / APP Team
#7 Posted : Friday, June 8, 2012 12:14:26 PM(UTC)
Simon / APP Team
Groups: APP Team
No.The compressor would not run with bad starting components. If it's getting less than 108v it would not work properly.
Simon.
hogo
#8 Posted : Friday, June 8, 2012 1:14:32 PM(UTC)
hogo
Simon.
Thanks Simon, for your help.
Howard
Simon / APP Team
#9 Posted : Friday, June 8, 2012 10:07:09 PM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
Guest
#10 Posted : Thursday, September 28, 2023 5:01:49 PM(UTC)
Guest
Rank: Guest
United States
If there is ice above the coils, would we need to replace the coils only or what else would need to be replaced? Compressor is running, and all parts on back seem ok. It just isn’t cooling. We were told by an appliance person that everything, including compressor, would need to be replaced.
