Eugene Thompson
#1 Posted : Wednesday, April 11, 2012 4:09:27 AM(UTC)
Eugene Thompson
the refrigerator is not coming on at all after it was cleaned.Is there a reset button somewhere or do i just change the circuit board?
#2 Posted : Wednesday, April 11, 2012 4:33:40 AM(UTC)
Replacement parts for Frigidaire FRS6B7EESB8 Frigidaire/refrigerator | AppliancePartsPros.com
What do you mean by "refrigerator is not coming on at all"
Is it totally dead no lights, display etc.?
What is running if anything?
How long have you waited? If it has lights etc., it could be that it is just in a defrost cycle.
If you left it for an hour and still nothing, try unplugging it for a couple minutes to see if it will reset.
Eugene Thompson
#3 Posted : Wednesday, April 11, 2012 4:59:02 AM(UTC)
Eugene Thompson
No lights at all and i already did those.i left it off overnight and have the same result.
#4 Posted : Wednesday, April 11, 2012 6:28:36 AM(UTC)
Here is a wiring diagram
http://manuals.frigidaire.com/p...f/Anderson/241636601.pdf
As you can see there is not a fuse or circuit breaker that will kill power to the entire unit.
Have you checked the voltage at the outlet or tried a different outlet?
If you have voltage at the outlet then you will have to check for voltage getting to the fridge.
