Aimin
#1 Posted : Thursday, March 29, 2012 4:39:11 PM(UTC)
Aimin
My double oven stop working a month ago. After I have changed thermal fuse and control panel, it worked, for one night! The next morning, it stopped working again. I checked to find out the fuse is out and I remembered that the R90-92 to be hot. So I order a control board and new thermal fuse. I put them back tonight and it worked! However I found that the parts R90-92 were pretty hot, and I am afraid that something else is wrong besides the board. Should these parts be hot? Is there a way to check? Thanks in advance!
Aimin
#2 Posted : Saturday, March 31, 2012 3:27:23 AM(UTC)
I cannot be of much help here as I cannot get a schematic of the board so I do not know what circuit those resistors are part of.
Manufacturers do not publish them.
I can give you the tech sheet in case you do not have it.
This may let you trace back from the resistors to see what components they control.
See the attachment.
File Attachment(s):
GBD277.pdf (505kb) downloaded 11 time(s).
Aimin
#3 Posted : Saturday, March 31, 2012 8:21:14 AM(UTC)
Aimin
Thanks! I was trying with these but unfortunately couldn't figure out. I do realize though that I didn't do the program Cavity size, would that be a reason? The other common thing I seems to get here is the transformer, would that lead to the problem I have described?
Aimin
#4 Posted : Sunday, April 1, 2012 1:39:18 AM(UTC)
Sorry but I do not know.
Whirlpool oven control board (Oven Repair (including Ranges and Cooktops))
by tdoran 3/2/2011 3:00:52 PM(UTC)
by hritchie 4/24/2009 2:03:36 PM(UTC)
