KeoweeHarry
#1 Posted : Sunday, November 27, 2011 6:11:55 AM(UTC)
KeoweeHarry
The wash temperatures have become reversed. When cold is selected, hot water flows in and vice versa. Similarly, the rinse water is now hot. (It should be cold.) I thought the hoses were reversed (unlikely since we've used the machine for 2½ years), but reversing them worked only once; then it went back to being reversed. What is wrong with this machine?
sidfink43
#2 Posted : Monday, November 28, 2011 5:23:53 PM(UTC)
sidfink43
Well that is unusual, but if it reversed again it should be ok now?
If not, try replacing the temp selection switch, and if that doesn't fix it the timer is the next suspect.
Here is the part
Part number: AP4261756
KeoweeHarry
#3 Posted : Monday, November 28, 2011 6:01:43 PM(UTC)
KeoweeHarry
Here is the part
If it is this switch, why would the rinse fill water come in hot? Isn't it more likely that the fault is with the inlet thermistor (vacuum) unit, Whirlpool part no. 387606?
KeoweeHarry
sidfink43
#4 Posted : Tuesday, November 29, 2011 4:01:31 AM(UTC)
sidfink43
That part number does not come up as a thermistor, but if there is a thermistor in your model that could also be the problem.
KeoweeHarry
#5 Posted : Tuesday, November 29, 2011 4:21:41 AM(UTC)
KeoweeHarry
sidfink43, APP calls it a "Vacuum Break". It's APP p/n AP3096264. Same item as shown on my Whirlpool parts list. I appreciate your help.
KeoweeHarry
sidfink43
#6 Posted : Tuesday, November 29, 2011 9:45:52 AM(UTC)
sidfink43
Yes, that is the part I found that corresponds to the factory part number
I don't think it has a thermistor in it, but check yours and see if it does.
KeoweeHarry
#7 Posted : Tuesday, November 29, 2011 10:30:35 AM(UTC)
KeoweeHarry
All I know is that Whirlpool calls it "Themister, Inlet" in their parts list. I have scheduled A & E Factory Service to come on Dec. 1. Do you have any comments re their service?
sidfink43
#8 Posted : Tuesday, November 29, 2011 11:26:54 AM(UTC)
sidfink43
I am not familiar with them, they may be contract repair techs for Sears. Do let us know what they do to fix it. You have an unusual problem and we certainly would like to know what was going on.
Good luck, hope they get everything up and going for you.
