Howdy: Discovered leak on outside of tub on bottom right corner, just above pump that drains the tub. Can't find leak on the inside... Not the original owner - I have no receipt. Manual claims 20 year warranty on tub. House is 10 years old, so I assume the machine is of the same vintage. Ideas on how I should proceed?? Any suggestions appreciated! Kevin
