jays327
#1 Posted : Friday, January 23, 2009 3:31:24 PM(UTC)
jays327
I have replaced the heat element, thermal fuse, thermostat, the main select switch and just purchased the three way switch the controls what temp i want to run at. hopefully that will work but can anyone give me an idea what i have missed or what i should do. i also made sure there wasnt any lint in the catch as well.
Thanks,
Jerad
kayakcrzy
#2 Posted : Saturday, January 24, 2009 4:05:23 AM(UTC)
kayakcrzy
Yes, you have never said, you checked the power coming to the back of the dryer where the cord goes in. People make an assumption, that if the dryer runs, then it is getting power. Not true. Voltage is lazy, and it travels through the path of least resistance, so if there is any power it will go to the motor, not the element. So take the panel off, and check the power. You might even go out to the dryer breaker, and flip it off and on a few times. But checking the power at the plug, is what you need to establish. Tom ApplianceEducator.com
Admiral Dryer Runs no heat in heat cycles, does not turn on in no heat fluff (Dryer Repair)
Belarus jennshuey 11/18/2016 11:06:43 PM(UTC)
Gas Dryer Runs No Heat (Dryer Repair)
by zinger 12/7/2012 6:41:31 PM(UTC)
dryer runs no heat (Dryer Repair)
by Jim Bags 8/31/2009 7:41:27 PM(UTC)
Timer does not advance dryer runs no heat (Dryer Repair)
by Rmelc1 7/20/2009 1:25:42 PM(UTC)
Dryer runs no heat, Please help (Dryer Repair)
by blindman 5/17/2009 6:30:38 PM(UTC)
by kwclark 1/24/2009 8:21:09 AM(UTC)
by misssue 1/23/2009 11:21:28 AM(UTC)
Dryer runs no heat (Dryer Repair)
by glennb 8/10/2007 9:19:09 AM(UTC)
by Wesley 7/24/2007 12:54:40 PM(UTC)
