Lynn
#1 Posted : Monday, November 5, 2007 3:25:39 PM(UTC)
Lynn
F7 keeps popping up and beeping and you clear it and it starts all over again, tried unplugging range and waiting and putting plug back but it still happens. Your replacement part says wiring may be different. You you send me info on installing replacement control panel Part #WB27K10007. Thanks
#2 Posted : Monday, November 5, 2007 4:26:33 PM(UTC)
Hi Lynn
The part number you posted is for the control board. Most likely the problem with your range is a bad control panel. The error code "F7" means one or more pads on the key pad are stuck.
To make sure which part is bad you have to unplug the range, open the control panel, unplug the key pad ribbon from the control board slot and plug the range back.
If the error code will show up again then replace the control board.
If the error code would not show up then replace the control panel.
The new control board comes with the installation instruction.
- The part number for the control panel AP2035212
- Here are the break down diagrams for the GE range Model JGBP86BEA3BB
Good luck.
dlynns47 (Dryer Repair)
by dlynns47 4/21/2011 9:43:39 PM(UTC)
Lynn88 (Refrigerator & Freezer Repair)
by lynn88 6/17/2009 5:47:07 AM(UTC)
Lynn Borum (Oven Repair (including Ranges and Cooktops))
by Lynn Borum 10/9/2008 9:57:51 AM(UTC)
