enrique
#1 Posted : Sunday, January 4, 2009 1:12:51 PM(UTC)
enrique
My washer does not want to dispense cold water during the cycles. I only get the hot water to come out. Have checked the lines and clean the wire mesh filters at both ends of the hoses but did not fix the problem I need some help.
kayakcrzy
#2 Posted : Sunday, January 4, 2009 3:36:27 PM(UTC)
kayakcrzy
As long as all the screens are clear in the hoses. I would replace the water valve. I good way to tell is if you do not hear a hum, when you ask for cold water, the water valve is most likely your problem. Tom
Cold water does not dispense (Washer Repair)
by enrique 1/4/2009 1:14:13 PM(UTC)
