Angezy
#1 Posted : Thursday, September 8, 2011 1:46:50 PM(UTC)
Angezy
if you just bought a drain pump for maytag neptune mah5500bww and the water still leaks all over the floor. What is the next thing i should check
sidfink43
#2 Posted : Saturday, September 10, 2011 5:38:29 PM(UTC)
sidfink43
See if you can check the hoses for some type of leak, or their connection.
Angezy
#3 Posted : Sunday, September 11, 2011 6:06:33 AM(UTC)
Angezy
Thanks i have checked all hoses and even connected another washer that works fine. If you are familiar with this model mah5500bww on the drain pump there is a overflow coming out of the drain pump and that is where the water is shooting out of in a stream like fashion.any help woud be greatly appreciated.
sidfink43
#4 Posted : Sunday, September 11, 2011 10:33:22 AM(UTC)
sidfink43
I am not aware of any overflow valve on this pump. The pressure switch is mounted on the pump and it may be that it is coming loose under the pressure, so check that out.. You may have to repalce the pump and/or the pressure switch depending upon which is the problem.
Angezy
#5 Posted : Tuesday, September 13, 2011 7:49:20 AM(UTC)
Angezy
Thanks Sidfink43, I have ordered the pressure switch. I am waiting for it to arrive. I will update on my progress. Thanks again for your help!!! I hope this does it...
sidfink43
#6 Posted : Tuesday, September 13, 2011 11:31:49 AM(UTC)
sidfink43
Great, let us know how it works out.
