spis
#1 Posted : Sunday, October 21, 2007 10:54:00 AM(UTC)
spis
Hi I have a problem with the relay of the motor sometimes works intermittent could it be a switch mtr problem or the motor?
#2 Posted : Monday, October 22, 2007 1:55:07 AM(UTC)
Pull front panel and check the motor connector, you might have a burnt pin. If ok, check your timer connector pins for a bad connection.
When the washer becomes intermittent, move the timer to another cycle, if now ok, you probably have a bad timer.
spis
#3 Posted : Monday, October 22, 2007 10:42:58 AM(UTC)
spis
The conectors are ok The washer fill water ok but when starts to wash the motor's relay work intermittent, then I turn the timer mannually, yust a little, and it works all the cycle then drain ok and in the spin cycle agan intermittent, the lid switch is ok, I can see some sparkle in the switch mtr of the motor
#4 Posted : Monday, October 22, 2007 2:50:53 PM(UTC)
Seems like a bad timer. I usually confirm by pulling cover off motor and check for burnt contacts.
spis
#5 Posted : Monday, October 22, 2007 7:03:02 PM(UTC)
spis
I found burn contacts inside the switch mtr, coul it be the problem?
spis
#6 Posted : Monday, October 22, 2007 7:08:50 PM(UTC)
spis
here are pics
spis attached the following image(s):
#7 Posted : Tuesday, October 23, 2007 1:02:00 AM(UTC)
Very rare these switches go bad unless oil gets in them. Verify with meter good ohms when activated; ie. less than 1 ohm.
Check timer also.
spis
#8 Posted : Wednesday, October 24, 2007 7:45:33 PM(UTC)
spis
OK guys. For your files I changed the swicht mtr and the washer works great again, the timer is ok, thank you for all your help
rmfield
#9 Posted : Sunday, October 28, 2007 2:49:10 PM(UTC)
rmfield
Moved to new post
GE Washer - Motor Intermittent (Washer Repair)
by rmfield 10/28/2007 3:17:31 PM(UTC)
