I have a Kenmore fridge, I ordered a new start -dev #2319793 and they said this superseeds my old start relay. I need help on how to rewire this to make it work please help!:confused:
Your new start device looks identical to the old one, just plug in the fridg connectors as they where originally and plug in the run capacitor.
Originally Posted by: richappy Your new start device looks identical to the old one, just plug in the fridg connectors as they where originally and plug in the run capacitor. My old relay looks different to the new one they sent me the wrong relay! I need relay #4357156.:mad:
They look identical on this site, just call them to get the right one.
Originally Posted by: richappy They look identical on this site, just call them to get the right one. I came home for lunch and turned the fridge on compressor comes on with the old start relay. It will run for 4 hrs. freezer side and fridge side getting good and cold, when it shut off and then trys to restart is when it has its problem and wont start!:confused:
You have a hard starting compressor, if you have an amprobe, you would probably see it draws excessive current while trying to start. Your old start device is probably ok. You could try a AP206490 ptcr and a klixon AP206490, as mentioned in my article "replacing compressor start devices", but the compressor may still not reliably start and you will need a meter to install.
