2 Pages12>
JimDaddy
#1 Posted : Saturday, February 12, 2011 12:41:31 PM(UTC)
JimDaddy
Washer tripped GFI, I reset GFI, now washer does nothing. Doesn't even try, sol.vils, dont open, no spin, nutin.
I tried turning the agitator by hand, it was very hard to turn and only moved about 3 inches and I cant move it again.
cammyj1967
#2 Posted : Saturday, February 12, 2011 12:54:31 PM(UTC)
cammyj1967
Check your fuse behind the control panel by pulling the 2 inside screws on the top and rotating it down. if so you have a lid switch assy that needs replaced.
JimDaddy
#3 Posted : Saturday, February 12, 2011 1:08:47 PM(UTC)
JimDaddy
Opened back of control panel.... I dont see a fuse.
cammyj1967
#4 Posted : Saturday, February 12, 2011 1:13:03 PM(UTC)
cammyj1967
please open the diagram for your model and look at the diagram for the base. where the lid switch plunger goes in to the control panel you will see a fuse holder. this website has a great breakdown.
cammyj1967
#5 Posted : Saturday, February 12, 2011 1:14:49 PM(UTC)
cammyj1967
JimDaddy
#6 Posted : Saturday, February 12, 2011 1:31:43 PM(UTC)
JimDaddy
Dont have diagram for base, but I followed the plunger into the control panel, unplug it and removed it. It appears sealed. Does it open? How? Plunger module has 4 electrical connections on it marked Neut, Line, Motor, Machine
cammyj1967
#7 Posted : Saturday, February 12, 2011 1:46:47 PM(UTC)
cammyj1967
Perhaps the model # i am seeing is different from your actual? By pulling up the diagram for your top the fuse is item #10.
JimDaddy
#8 Posted : Saturday, February 12, 2011 1:55:00 PM(UTC)
JimDaddy
The part I removed is part #15 on the "top" diagram. If there is a fuse inside, how do I get to it? Or is the switch bad. ?
cammyj1967
#9 Posted : Saturday, February 12, 2011 2:04:28 PM(UTC)
cammyj1967
Ok that is the newer style of lid switch assy and it will prevent the machine from doing anything including fill, spin. It would be a good bet that the switch would need to be replaced. You can however ohm the switch out to be sure if you have the wiring diagram for your washer.
JimDaddy
#10 Posted : Saturday, February 12, 2011 2:09:56 PM(UTC)
JimDaddy
Ok, thanks, now all I gotta do is find my ohm meter.....lol
2 Pages12>
