2 Pages12>
Scottrse1
#1 Posted : Thursday, December 6, 2007 8:44:45 AM(UTC)
Scottrse1
The refrigerator / freezer works great, but a reoccurring problem for years is the defrost drain hole from the freezer to the refrigerator freezes up a few times a year (or more). This causes a water backup which eventually it "rains" in the refrigerator. I found part AP118347 on your site "Drain Tube Freeze Up Kit" which I assume was an add on from the mfgr to deal with this issue. How does it install, does it come with detail instructions for installation into a unit that doesn't already have the wiring in place, etc. I think the settings in the freezer & frig are correct as I don't have ice in the milk and the ice cream is hard. The seals around the doors all look good. I don't have moisture around the door openings, etc. Can you help?
Scott
#2 Posted : Thursday, December 6, 2007 3:36:04 PM(UTC)
This is a very common problem with Amana top & bottom refrigerators and this kit works good. Honestly I do not remember the installation process (last time I did it was a few years ago) and I'm not sure about the installation instructions. You can call the APP (877-477-7278) and they will find it for you.
Scottrse1
#3 Posted : Sunday, December 9, 2007 6:20:43 AM(UTC)
Scottrse1
Thanks Gene for the response. I've dealt with the problems for years and appreciate your professional input to help me resolve it.
pjy
#4 Posted : Tuesday, September 2, 2008 2:55:44 PM(UTC)
pjy
Great help and advice! I have the same problem but do not know how to remove the freezer 'floor' tray. I removed the freezer rear panel to expose the evaporator but could not access the drain. I can't find any detailed diagrams on this old model. Any suggestions?
#5 Posted : Tuesday, September 2, 2008 4:55:17 PM(UTC)
pjy,
What is the complete model number of the refrigerator?
pjy
#6 Posted : Wednesday, September 3, 2008 10:53:49 AM(UTC)
pjy
Wow, I did not expect such a rapid response!
Model is TL20NL, Manufacturing # is P1106213WL.
As I mentioned previously, I opened the rear of the freezer but could not access any drain.
Thanks again for such a quick reply!
#7 Posted : Wednesday, September 3, 2008 1:29:34 PM(UTC)
Locate the drip tray (#26 on the break down diagram) under the evaporator coil. The drain hole is in the center of the tray.
Use a hair dryer to defrost it. You can install the drain tube freeze up kit (#20 on the break down diagram) to prevent future freezing.
Here are the break down diagrams for the Amana refrigerator Model TL20N
pjy
#8 Posted : Friday, September 5, 2008 4:34:48 PM(UTC)
pjy
Thanks so much! I will take a look at the diagrams to see how to take the unit apart (once I consume all the items currently in the freezer. Unfortunately I filled it up a few days before this problem happened!).
AngeloMangelo
#9 Posted : Thursday, September 24, 2009 6:49:45 PM(UTC)
AngeloMangelo
Gene,
I have an Amana BX21V bottom freezer and it sounds like I have the same issue. When I removed the rear panel in the freezer, the coils were completely frozen. I defrosted it several times and it keeps occuring. Would the Drain Tube Freeze Up Kit (AP118347) also work for me.
#10 Posted : Friday, September 25, 2009 1:24:39 PM(UTC)
Originally Posted by: AngeloMangelo Go to Quoted Post
Gene,
More likely the problem is a faulty defrost system.
Perform the troubleshooting as described in one of our previous posts: http://forum.appliancepartspros...frigerator-too-warm.html
The defrost timer is shown as #342 on the diagram.
The model number you posted is incomplete. Verify and repost it.
2 Pages12>
