mestes
#1 Posted : Thursday, January 6, 2011 7:49:40 AM(UTC)
mestes
I have a Roper Washing machine and when I start any cycle it will fill and then stop if I turn the dial to rinse it will rinse but then stop and not change to the spin cycle.
What could be the cause or steps to trouble shoot?
magician59
#2 Posted : Thursday, January 6, 2011 8:05:36 AM(UTC)
magician59
See if you can hear the timer running after the fill.
mestes
#3 Posted : Thursday, January 6, 2011 8:12:41 AM(UTC)
mestes
ok I will check
mestes
#4 Posted : Thursday, January 6, 2011 8:29:56 AM(UTC)
mestes
do you mean hear it running when it should cycle but stops? cannot hear anything but the drum spinning when it first fills.
mestes
#5 Posted : Thursday, January 6, 2011 8:52:31 AM(UTC)
mestes
removed the top panel screws and check the wiring to make sure nothing was loose or shorting out, and now machine cycles properly what could I have done to fix it?
magician59
#6 Posted : Thursday, January 6, 2011 9:29:57 AM(UTC)
magician59
You probably made a questionable connection more solid, by jiggling wires or checking harness connections.
mestes
#7 Posted : Thursday, January 6, 2011 9:33:56 AM(UTC)
mestes
I have tried running a few cycles since and the issue happens still if I fiddle with the timer or lift the lid and back down it seems to work would this be a possible bad timer or failing one?
magician59
#8 Posted : Thursday, January 6, 2011 11:11:53 AM(UTC)
magician59
It could be a bad timer or a bad harness connector.
Guest
#9 Posted : Monday, June 13, 2022 12:34:57 PM(UTC)
Guest
Rank: Guest
United States
Have a Roper machine it will fill, go into wash cycle but won't run through. What do I need to do
