My gas oven ignitor lights the pilot and the pilot doesn't go out. If I turn the thermostat knob to adjust the burner to go on no gas is sent to the burner. I see that it looks like the safety valve and the thermal couple are all one unit, part # (AP4276134) or (Y0056020). Is there a seperate part # for the thermal couple and can this be removed? Is the safety valve bad? or is thermal couple bad? Does anyone know where I can purchase any of these parts? Any help on this matter would be appreciated. Thanks
Chris
Originally Posted by: chrissayah My gas oven ignitor lights the pilot and the pilot doesn't go out. If I turn the thermostat knob to adjust the burner to go on no gas is sent to the burner. I see that it looks like the safety valve and the thermal couple are all one unit, part # (AP4276134) or (Y0056020). Is there a seperate part # for the thermal couple and can this be removed? Is the safety valve bad? or is thermal couple bad? Does anyone know where I can purchase any of these parts? Any help on this matter would be appreciated. Thanks
Chris Chris, I'd be 95% sure your problem is in the thermocouple, but I can't find a part number for the part itself(separate from valve body). And our parts department information indicates, that part number is discontinued by the manufacturer (Y0056020). You may want to check with a local parts or service company, to see if they have one in stock, or you may want to check the internet under"Antique Appliance Parts" dealers. :( :( :( Good Luck,
I am a landlord and alot of my apartments still have these gas on gas/ combination gas stove and heater. My stoves still run as good as the day I bought them. There is a antique gas parts store in Manchester NH. They specialize in Magee and Glenwood discontinued parts. I have found the parts I need there. I checked the store for you and they do have the part you need, call them 603 625-5440. Their @156 Bridge St 03104. Good luck these stoves are awesome and it is too bad no one makes them anymore.
Originally Posted by: GlenwoodMagee I am a landlord and alot of my apartments still have these gas on gas/ combination gas stove and heater. My stoves still run as good as the day I bought them. There is a antique gas parts store in Manchester NH. They specialize in Magee and Glenwood discontinued parts. I have found the parts I need there. I checked the store for you and they do have the part you need, call them 603 625-5440. Their @156 Bridge St 03104. Good luck these stoves are awesome and it is too bad no one makes them anymore. Glenwood, Thanks for the Parts information and source. It will come in handy as a reference and parts source for others. Thanks Again, :) :) :)
