cbudka
#1 Posted : Tuesday, November 2, 2010 6:39:40 AM(UTC)
cbudka
This unit does not seem to be getting power. I checked the electrical outlet for continuity. I checked the breaker to make sure it hadn't tripped. I plugged the unit into a separate outlet on the other side of the house via an extension chord. The unit will not power up once the wash cycle button have been chosen. Apparently, it stopped mid cycle as the bottom pan is full of water. Can anyone advise as to what could be the culprit here? Is this reasonable to fix, and, is it a DIY job? Please advise.
Thanks in advance!
Chris
#2 Posted : Wednesday, November 3, 2010 2:06:52 AM(UTC)
Replacement parts for WHIRLPOOL KUDP01FLBT3 Dishwasher | AppliancePartsPros.com
A common problem is a blown fuse (Item 6 in Section 2)
If it is blown be sure to use the new harness that comes with the fuse.
