Parts came in yesterday, changed the drain pump, thrust bearing & belt. My old thrust bearing was reduced to a pile of shims it appeared. Didn't even recognize the old spacer that came with the kit, unless its been changed form the original parts.
I've run a few loads of laundry through it so far and all appears well.
Thanks again.
Originally Posted by: Raulg Parts came in yesterday, changed the drain pump, thrust bearing & belt. My old thrust bearing was reduced to a pile of shims it appeared. Didn't even recognize the old spacer that came with the kit, unless its been changed form the original parts.
Thanks again. Raul, Great job, Glad to hear you're up and running. Apparently you had an "original" thrust bearing assembly, it's been revised a couple of times since then. But not to worry, as long as you've followed the instructions , you'll be fine for a long while. Good Luck, :) :) :)
