sweal
#1 Posted : Monday, September 27, 2010 2:20:02 PM(UTC)
sweal
my dishwasher won't drain, i have cleaned out the filters and checked the hose drain. There is a little part in the back that can unscrew and i have taken it out and made sure that the little thing is still going up and down with the spring. what else can I do to fix this??
#2 Posted : Monday, September 27, 2010 6:11:17 PM(UTC)
I cannot find any info on this unit but it is probably a GE unit.
I am assuming the part you mention is the piston & nut.
I am assuming that not only did it go up and down, the rubber seal on it was OK.
Check that the wash/drain solenoid on the left hand side of the pump is being actuated (pulled down) when the unit should be draining.
