tracy1878
#1 Posted : Sunday, July 20, 2008 6:37:16 AM(UTC)
tracy1878
We have the above mentioned oven that up until yesterday worked just fine. The burners on top work fine, but when you turn on the oven, the display says it's heating, but neither elements warm up, I've tried both regular baking and the broil function. I have read in one of your blogs (thank you very much!) that this is possibly a fuse malfunction. Do you have any other advice before we tear this bad boy apart and try to fix it ourselves? Also, is there a way you can tell that the fuse is burnt, like an automotive fuse?
Also, I may be off on the age of this oven, it was already in our house when we bought it last year.
Thanks again
tracy1878
#2 Posted : Monday, July 21, 2008 8:02:16 AM(UTC)
tracy1878
anyone??? Need some help here please
#3 Posted : Monday, July 21, 2008 8:37:32 PM(UTC)
There is the fuse (#9 at the break down diagram) which has to be checked for continuity and replaced if it's open.
- The fuse Part number: AP3026588
tracy1878
#4 Posted : Tuesday, July 22, 2008 6:39:13 AM(UTC)
tracy1878
thanks for the help with the diagram. was able to find the problem much faster and save our family the 60 dollar service call. the problem is now solved and my wife will reward with baked goods.
Nebcoyote
#5 Posted : Friday, June 22, 2012 8:22:26 AM(UTC)
Nebcoyote
Gene,
I have the exact problem described in this thread. Is the part still available? In the diagram, #9 looks like a long wire and not a fuse. Is this fuse accessible and easily replaced and is there a step by step on how to accomplish this?
Thank you in advance.
#6 Posted : Friday, June 22, 2012 1:34:29 PM(UTC)
I fixed the link for this diagram so, you can find it easier.
This is a simple 20A fuse which is located on the back of the range.
