Hi, my Maytag washer will occasionally splash/leak water out of the injector sleeve when filling. What would cause this and what part, if any, do I need to replace....
Originally Posted by: Rocky56 Hi, my Maytag washer will occasionally splash/leak water out of the injector sleeve when filling. What would cause this and what part, if any, do I need to replace.... Rocky, You most likely have deposits built up on the injector valve and nozzle, under certain conditions(water pressure, usually)can implicate an intermittent leak. I reccomend you replace the: Injector valve Injector nozzle Hose clamp clean the calcium deposit from the plastic housing, and clean the hose and valve screens of debris. Part number: AP2920314
Thanks Joe, I will give this a try....
Originally Posted by: Rocky56 Thanks Joe, I will give this a try.... You're welcome, Glad to have helped, :) :) :)
