[FONT="]The machine stops after the rinse cycle, and the timer continues to the end of the cycle without having drained or spun.
If I turn the knob all the way around to spin again, the washer will drain and spin. The pump and drain hose are clear. [/FONT]
Just a quick reminder to check the safety switch on the door. It can allow your machine to do or not do a lot of crazy things!!!!
I checked the lid switch It's ok
The small round coupling between motor and water pump may be bad. If not, sure sounds like a timer problem!
