jlagle
#1 Posted : Wednesday, June 2, 2010 12:23:54 PM(UTC)
jlagle
I'm have some issues with my ice maker. About 2 years ago the led begain to flash two quick flashes the a pause the repeat. The ice maker was working fine, but it was a little slow. A couple of days ago the ice maker refused to dump the ice that was currently in the mold, I removed the ice maker and used some water to remove the ice. After I reinstalled the ice maker it is doing nothing, the led is still flashing, but it wont fill with water. Any ideas/suggestions?
Joe Lagle
#2 Posted : Wednesday, June 2, 2010 6:47:48 PM(UTC)
Hi Joe,
Open the freezer door. Close the flapper door on the left side and watch the LED on the right side. If it's blinking, most likely the problem is a bad optic PC boards.
- The PC boards kit Part number: AP3137510
