oven sensor tests open how hard is it to change sensor
Power it down by throwing the breaker. Just one or two screws to remove the sensor. Gently pull it out ntil you can see the connector. (Be careful not to let the connector fall back into the unit; then you will have to pull the oven out of the wall to retrieve it.) Installation is reverse. Part number: AP4009009
