You have been a member since:: 12/8/2009(UTC) Posts: 5
Everything works but the oven will not lite. How can i test to find out what part i need?
Does the Bake igniter (#14 on the diagram) glow? Gene.
Originally Posted by: Gene Does the Bake igniter (#14 on the diagram) glow? Gene. yes it does.
yes it does glow but does not lite.
Most likely the problem is a weak igniter. New igniter comes without mounting bracket. You have to use the bracket from the old igniter. Be very careful not to break the coil. - The igniter Part number: AP2934763
Originally Posted by: frednk yes it does glow but does not lite. Gene this one you have sent a picture of is just like the broiler one. The one i have is flat and only two inches long. And it is for the oven.
According to the diagram and parts list, both Broil and Bake igniters in this oven are identical and should look as shown on the previous picture. If the Bake igniter in your oven has a short ceramic, that means it had been already replaced by someone else. Electrically igniters with long and short ceramics are the same and are interchangeable. The only difference is the igniter with short ceramic comes with the mounting bracket what makes the installation easier. - The flat igniter with the short ceramic Part number: AP2634719
Originally Posted by: Gene Does the Bake igniter (#14 on the diagram) glow? Gene. Gene I took the ignitor out of the oven and to my surprise it is not 2 inches but 2 inches is all you see, it is 5 1/2 inches long so i should order the long one right.
