My parents have a Bosh dishwasher in a home they just purchased that won't quit beeping every so many minutes after the dishes are clean. Is there a way to shut the alarm off? i'm assuming there has to be, but I can't figure it out.
PLEASE help!
thanks.
It's model SHU9925uc/12
Thanks. Does that stop it from beeping completely or just when it finishes. they do not want it to "ever" beep if possible. :)
When cycle is done it beeps to let you know about it. As long as the "on-off" switch is in "off" position there is no power to the dishwasher controls.
They tried to turn the power off, but as you said there is no power to the controls so the dishwasher cannot be run. We're, therefore, concluding that there is no way to stop the beeping at the end of the cycle. The problem is they like to run the dishwasher and then go to bed. They don't want to wake up, get out of bed and turn the "Beeping" off. they just don't want it to beep in the first place.
Thanks for the help anyhow. Please correct me if we're wrong!
Groups ready for retrieval: Registered
Hey Gene,
To follow up on my Bosch Dishwasher I am getting two error codes a Reg Wash and Delicate/Econo buttons flash after a diagnostic run.
The machine will not turn on.
I replaced the control module - no affect.
Any suggestions from the MAN?
How did you run the test?
Did you check the on-off switch and the micro switches on the door latch for continuity?
Hey Gene, Thanks for getting back to me. The test was run as described in the Bosch trouble shooting manual. I did not test continuity of the on/off or micro switches. Is there a pdf on running those tests? Will.
