I have an Amana AOES3030WW gas wall oven. When I set the temp and press Bake the oven makes a little click on the right side of the control panel then shuts itself off. The clock is working and if I keep pressing the bake button over and over eventually it will work.
I orderd a clock controller part# 31746801 do you think this will fix the problem?
Thank you very much Gene!!
