pinzou
#1 Posted : Thursday, May 29, 2008 7:45:00 AM(UTC)
pinzou
I have an Americana stove made by GE. One of my burner stop working, I noticed the element is brioken so I changed the element and plug but it's not working but the light on the dash stay red. There is no power from the plug, could it be the control switch? Please reply.
Appliance repair in OC
#2 Posted : Thursday, May 29, 2008 9:21:36 PM(UTC)
Most likely it's that switch
Changing from small to big burners (Oven Repair (including Ranges and Cooktops))
by stevekauss 4/10/2024 2:06:45 PM(UTC)
Remove bosh burners from cooktop (Oven Repair (including Ranges and Cooktops))
by stevekauss 4/8/2024 9:58:44 PM(UTC)
GE Monogram burner base (Oven Repair (including Ranges and Cooktops))
by DaveCrmr 3/10/2024 9:00:02 AM(UTC)
Burner heating without cooktop being switched on (Oven Repair (including Ranges and Cooktops))
by nvreds 2/25/2024 10:40:40 AM(UTC)
Russell Range 6-burner available (Oven Repair (including Ranges and Cooktops))
by scott99 2/20/2024 4:40:34 PM(UTC)
bad sitch to one burner (Oven Repair (including Ranges and Cooktops))
by Guest 1/27/2024 7:51:23 PM(UTC)
burner takes forever to heat a pan (Oven Repair (including Ranges and Cooktops))
by Guest 1/8/2024 11:34:43 AM(UTC)
GE Glasstop stove burner control knob (Oven Repair (including Ranges and Cooktops))
by Guest 9/17/2023 5:25:35 AM(UTC)
Maytag MGR6875ADW Double Oven - Burner top (Oven Repair (including Ranges and Cooktops))
by gnieciag 8/29/2023 5:38:52 PM(UTC)
Frozen burner bolts (Oven Repair (including Ranges and Cooktops))
by Guest 7/1/2023 9:41:51 PM(UTC)
DCS 6 burner range igniter issue (Oven Repair (including Ranges and Cooktops))
by Dcsovenrepairguy 7/1/2023 12:42:26 PM(UTC)
range burners and oven failed simultaneously???? (Oven Repair (including Ranges and Cooktops))
by barrot@bellsouth.net 6/20/2023 9:45:47 AM(UTC)
LG Gas Stove fg4331es.fstelga burners will not stay on (Appliance Parts)
by ivel50 6/12/2023 11:15:10 AM(UTC)
Burner supply tube fabrication (Oven Repair (including Ranges and Cooktops))
by Veem 3/17/2023 11:45:57 AM(UTC)
Frigidaire BGGF3042KFC - burner issue (Oven Repair (including Ranges and Cooktops))
by canooten 1/26/2023 12:22:58 PM(UTC)
