Discuss
Oven Does Not Work
 in
The Only Thing That Works Is The Cooktop..
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Does Not Work
  #1 (permalink)
Old 08-28-2007, 08:14 AM
JEANNIE JEANNIE is offline
Junior Member
JEANNIE is on a distinguished road
Angry Oven Does Not Work
Model Number: PLES389ECC   Brand: Frigidaire   Age: 1 - 5 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-28-2007, 11:26 AM
Admin / APP Team Admin / APP Team is offline
Administrator
APP Team
Admin / APP Team has disabled reputation
Default
Is the clock dead?
  #3 (permalink)
Old 08-28-2007, 01:24 PM
Junior Member
Default
No The Clock, Timer, Nothing Works Except The Stovetop
  #4 (permalink)
Old 08-28-2007, 01:47 PM
Junior Member
Default
yes the clock is dead
  #5 (permalink)
Old 08-29-2007, 09:08 AM
Administrator
APP Team
Default
If you know how to use a voltmeter, see if you get 110 volts to the clock (there is really no other way to check, other than just taking a guess).
If the clock gets 110 volts, the clock is bad (click for replacement clock), otherwise it's probably one of the safety thermostats on the back of the oven. This is not an easy job. The thermostats are mounted on the back wall and to check them the oven will have to be removed.
  #6 (permalink)
Old 08-29-2007, 11:34 AM
Junior Member
Default
Just So Everyone Will Know, It Wasnt The Clock/timer/electronic (for 156.00) It Was A Sensor Probe (easy To Install) 28.62 Thanks For The Help.
  #7 (permalink)
Old 08-29-2007, 03:07 PM
Administrator
APP Team
Default
Hmm. That's odd. If the sensor was bad, the clock would still display time or usually an error code. In other words, a faulty sensor does not cut power to the clock...
Either way, I'm glad it's fixed (wasn't trying to sell you a new clock ).
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool AC won't work lemiley Heating, Ventilation, and Air Conditioning (HVAC) 9 11-09-2008 12:43 AM
Cold/Cold will not work, all others do work!? MiniPants Washer Repair 10 08-30-2007 08:02 PM
Oven does not work... Ruben Oven Repair (including Ranges and Cooktops) 1 08-17-2007 09:02 AM
oven won't work cherylknudsen Oven Repair (including Ranges and Cooktops) 1 08-11-2007 05:43 PM
$200 and still don't work Rakar Dishwasher Repair 2 07-27-2007 10:14 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
