| » Range won't turn off |
Model Number: NGSE3WASC Brand: Frigidaire Age: 1 - 5 years
Finished cooking with the oven, pushed the "Clear Off" button and it didn't turn off.
Turned the oven off at the breaker, rechecked last night and same thing. Gut feel says it is the panel behind the clock, could it be something else? If it is the panel, is it a job for a DIY'er Thanks Related Models |
Most likely the problem is a bad control board aka a clock/timer. The model number you posted does not come up. Verify and repost it.
__________________
Professional appliance repair in Orange County, California. |
The control board has to be replaced together with the overlay because it's glued to the control board.
- The control board Part number: AP3693959 - The overlay Part number: AP2126498 Gene.
__________________
If you know how to use a simple tools, this part is not too difficult to replace yourself. Power off the range and remove the rear control panel cover. Remove the screws holding the control board and pull it out as far as the wires go. Remove the wires (one at a time) from the old control board and connect them to the new one.
__________________
Professional appliance repair in Orange County, California. Last edited by Gene : 11-09-2009 at 04:01 PM. |
__________________
| Display Modes | |
| GE Standalone Range display won't turn on | odonnelltw | Oven Repair (including Ranges and Cooktops) | 3 | 10-09-2009 04:23 PM |
| Gas Range Igniters Don't Turn Off | Dmarton | Oven Repair (including Ranges and Cooktops) | 3 | 09-21-2008 09:49 AM |
| Frididaire range oven won't turn off. | Kenymac | Oven Repair (including Ranges and Cooktops) | 1 | 03-19-2008 01:53 PM |
| Range Top Gas Won't Turn | APSMARK | Oven Repair (including Ranges and Cooktops) | 0 | 11-08-2007 07:15 PM |
| Norge Range alarm won't turn off | leooneil | Oven Repair (including Ranges and Cooktops) | 0 | 08-26-2007 10:59 PM |
