Discuss
Thermador heating element problem
 in
Lower heating element no longer heats, appears to be cracked and bubbled up like something was baked on it, but
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermador heating element problem
  #1 (permalink)
Old 10-27-2009, 08:59 PM
RSchuetze RSchuetze is offline
Junior Member
RSchuetze is on a distinguished road
Default Thermador heating element problem
Model Number: SMW272YB   Brand: Thermador   Age: 5 - 10 years
Lower heating element no longer heats, appears to be cracked and bubbled up like something was baked on it, but the stuff bubbled up does not appear to be food, but more like metal that has melted. Is this likely? Also control panel is going dim for the 3rd time. What do you suggest?
Related Models
Thermador SMW272YB AFTER S/N 8204
Thermador SMW272YS AFTER S/N 8204
Thermador SMW272YW AFTER S/N 8204
Thermador SMW272ZS AFTER S/N 8204
Thermador SMWS72YP AFTER S/N 8204
Bosch SMZ3022
Bosch SMZ3044
Bosch SMZ3055
Bosch SMZ3077
Bosch SMZ3088
Whirlpool SN
Amana SNAC-700.A Commercial Microwaves
Amana SNAC-700.B Commercial Microwaves
Amana SNAC-7TP.A Commercial Microwaves
Amana SNAC-7TP.B Commercial Microwaves
Amana SNAC700 Commercial Microwaves
Amana SNAC700.C Commercial Microwaves
Amana SNAC700.D Commercial Microwaves
Amana SNAC7TP.003 Commercial Microwaves
Amana SNAC7TP.004 Commercial Microwaves
Amana SNAC7TP.005 Commercial Microwaves
Amana SNAC8LW Commercial Microwaves
Amana SNE26AA Range - Electric Std Delaware
Amana SNE26CB Range - S/c S/i Ddraft Gas
Amana SNE26ZZ Range - S/c S/i Ddraft Gas
Whirlpool SNFGA
Amana SNK26AA Range - S/c S/i Ddraft Gas
Amana SNK26AA0 Range - S/i Std Gas
Amana SNK26AA5 Range - S/i Std Gas
Amana SNK26CB Range - S/c S/i Ddraft Gas
Amana SNK26CB0 Range - S/i Std Gas
Amana SNK26CB5 Range - S/i Std Gas
Amana SNK26FS Range - S/c S/i Ddraft Gas
Amana SNK26FS0 Range - S/i Std Gas
Amana SNK26FS5 Range - S/i Std Gas
Amana SNP26AA Range - S/i Std Gas
Amana SNP26AA0 Range - S/i Std Gas
Amana SNP26AA5 Range - S/i Std Gas
Amana SNP26AH0 Range - S/i Std Gas
Amana SNP26CB Range - S/i Std Gas
Amana SNP26CB0 Range - S/i Std Gas
Amana SNP26CB5 Range - S/i Std Gas
Amana SNP26ZZ Range - S/i Std Gas
Amana SNP26ZZ0 Range - S/i Std Gas
Whirlpool SNPA
Whirlpool SNPA-0 Pasta Maker Stand Mixer Attachment
Amana SP17A Ref - SXS/I&W
Amana SP17A-A Ref - SXS/I&W
Amana SP17A-AG Ref - SXS/I&W
Amana SP17A-C Ref - SXS/I&W
Amana SP17G Ref - SXS/I&W
Amana SP17G-A Ref - SXS/I&W
Amana SP17G-AG Ref - SXS/I&W
Amana SP17G-C Ref - SXS/I&W
Amana SP17N Ref - SXS/I&W
Amana SP17N-A Ref - SXS/I&W
Amana SP17N-AG Ref - SXS/I&W
Amana SP17N-C Ref - SXS/I&W
  #2 (permalink)
Old 10-28-2009, 03:40 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Replacement parts for SMW272YB models | AppliancePartsPros.com
Yes the element has to be replaced, it had a hot spot and the internal heating wire has broken.
To double check it remove it and check it with a meter usually around 10 to 20 ohms.
You will have to replace the control again.
I cannot say that the following applies to this unit but it is common on other units especially JennAire.
On the board there are a number of electrolytic capacitors, one or more of them are in the displays power supply. Over time they loose the ability to hold a charge and the display dims till it is unreadable. You could try replacing these capacitors. Unfortunately I do not know which one is for the display so I would replace all off them. This has about an 80% chance of fixing the board.
__________________
  #3 (permalink)
Old 10-28-2009, 06:22 AM
Senior Expert
APP Volunteer
Default
Also here is a good thread about dim displays
Thermador display is very dim
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador dual fuel bake/heating element replaced, still not working socalmat Oven Repair (including Ranges and Cooktops) 1 10-28-2009 02:03 PM
New Heating Element not the problem jlfowble Oven Repair (including Ranges and Cooktops) 0 03-09-2009 01:43 PM
New Heating Element not the problem jlfowble Oven Repair (including Ranges and Cooktops) 0 03-09-2009 01:41 PM
Thermador broiler element not heating Mash Oven Repair (including Ranges and Cooktops) 1 11-22-2008 04:18 PM
Heating Element Problem (No Heat) Unknown Dryer Repair 2 07-23-2008 09:48 AM
